Hi all,
I am having trouble assigning / accessing a static IP address to a wi-fi camera that I'm using as a baby monitor. Network is R7000 Router with Tomato Shibby software. I recently upgraded to the most recent software version to see if it fixed my problem, but to no avail.
The Camera is a Foscam unit and is configured with my wireless settings. Camera is set to obtain IP address from router. MAC address (of the wifi port) is bound to a static ip address outside of my normal dynamic range.
During initial setup, everything works fine. After a few hours to a few days, I lose connection with the router and can not access the wireless camera. No error lights on the camera. If I log into the router, I can see the camera under device list, with RSSI and quality, but no TX/RX rate appearing. The lease field is blank. I have set the static lease time to "infinite" without resolution. Settings for the camera seem to match what I used to statically assign my desktop computer, which works like a champ.
If I reset the router, everything is fine again for a short period, and then the same problem resumes. Any suggestions or help on how to fix this problem would be greatly appreciated.
Casm
