upgrade between different tomato versions
7 posts / 0 new
jrieden
currently running version
Tomato Firmware v1.28.9053 MIPSR2-beta K26 USB Ext
and want to uprade to latest Toastman's f/w.
Can I upgrade directly to Toastman, or via dd-wrt or ??
Do I need to clear nvram after flashing ? before flashing ?
Brandon C
You can go directly to
You can go directly to Toastman's Tomato version. You don't have to clear nvram but some folks prefer to just to make sure it's a cleaner upgrade.
pela020
A similar question:
A similar question:
Is it possible to go from Tomato Firmware v1.28.7440 MIPSR2-Toastman K26 USB Ext to the latest without losing all settings?
Brandon C
You can update to a newer
You can update to a newer version without erasing the settings. I believe most people back up their settings, upgrade and erase everything and then when it reboots either change the settings manually or restore the backup.
pela020
OK, thanks
OK, thanks
Toastman
If you restore your old
If you restore your old configuration then you have effectively restored exactly what you just erased.
Use this method instead http://www.linksysinfo.org/forums/showpost.php?p=362345&postcount=221
pela020
Great, then I will be able to
Great, then I will be able to import only the things i really want to. Perfect
