vmlinuz Problem
8 posts / 0 new
teamworker
vmlinuz Problem
Hello Community,
on my Netgear WGR614Lv8 with dd-wrt mini-Build 11218 from elko. I configure a VLAN02 on Port 4. After
reboot, only the Port 4 answer of a ping (192.168.1.1)
Hardreset 30,30,30 to clear NVRAM dosen't resolv the
Problem.
The litle Utility PumKIN let see me the message:
'vmlinuz' of tpye 'Octet'is requested from 192.168.1.1
How can i resolv that Problem?
Where can i download only the vmlinuz file?
I have no Serial Cable at Time.
when i rename *.chk file to vmlinuz and send to router..reboot..ask again for vmlinuz..
Thnx for Help[/img]
teamworker
:? ok no help -- shit-happens
i will by serial cable :roll:
Where is the community ^^
teamworker
@Tathagata Das
@Tathagata Das
I configure exactly this:
http://www.geek-pages.com/articles/latest/dd-wrt_-_setting_up_a_separate...
Then reboot the router.
With result, only LAN Port 4 sending signal of tftpd und ask me to give vmlinuz.
all 10 sek send the message again from internal tftpd (Router).
I can't send a new *.chk file with tftp to 192.168.1.1
TimeOut error.
ping 192.168.1.1 only on LAN Port 4 give answer.
I check this with WireShark and CrossOver Cable.
All other Ports are noise...
I have many time to try a hardreset 30,30,30 ...better 1 h, 1h, 1h, but nothing.
no clear NVRAM.
Any Solution? or by serial cabel and then stop bootloader.
Try to "clear NVRAM"
tftpd > etc
Thx for help
teamworker
Hi Tathagata Das,
Hi Tathagata Das,
I will check every LAN Port on the router direct with CrossOver Cable and WireShark. Router LAN 1 --- > PC WireShark, Router LAN 2 ----> PC etc....etc
I see only on Port 4 send TFTP a read-request for vmlinuz, every 10 sec..again
Only Port (4) accept icmp-echo-reply
I wondering to why only Port 4?
See my config e.g. VLAN2 isolated for Port 4.
wondering..wondering... i exactly type this example down.
Result:
TFTPD (on Router, only Port 4) is already in exclusiv Mode (read-request) for vmlinuz, and can't write the new *.chk file too.
Update: no chance Hardreset 3-5 Sec not work really.
greetings teamworker
teamworker
All LAN Port 1-3 blinking
All LAN Port 1-3 blinking when Ethernet-Cable plug-in.
Only Port 4 answer on ping.....and send signal of tftpd request to vmlinuz..
By configuration Link, i have the script save as Startup-script for Boot & Firewall. Then take a reboot per putty (ssh)
I wondering that the Hardreset not work.
3-5 sec or 30,30,30
I will by serial Cable und do tftp>nvram erase etc...
teamworker
Hello, Tathagata Das
only LAN Port 4 give reply of ping.
I'm more of 20 year's engineering networks and network services.
I take many time with network diagnostic, cisco configuration, vlan's etc.
I big..big wondering, only LAN Port 4 give READ-request for vmlinuz to my PC.
Why vmlinuz?, what search the bootloader or tftpd to automatic the REQUEST for
vmlinuz. Power off the router and than 8 sec later become the request (READ) not
write to my TFTPD server (PUMPKIN a litle tftpd server is runing on my Vista PC)
I'can't upload screenshot to this forum.
Please send my your e-mail per PM, i will send you screenshots.
Big thx teamworker from germay and a happy new year
teamworker
Screenshot on the way..
Thank you for your Work...
teamworker
Hello ..hello ?? Tathagata
Hello ..hello ?? Tathagata Das
Whats wrong, your understand me.....wowoowowwww
Have you see my screens etc..and read it?
- I can't reset router with 3-5-sec or 30,30,30 sec hardreset.
- How than update the *.chk file ????? there is no runing vmlinuz (kernel) Operating System on the router
- Upgrade ( or setting defaults) from GUI, no httpd Server runing.... only 4 Port answer of ping..
- How search tftp to upload the vmlinux?
thx for to mean well with this Problem.
I can't be bothered.
please close thread...
