Voxel V1.0.4.4HF-HW OpenVPN Issues
2 posts / 0 new
GiGNet
Hi all. So while the OpenVPN client contained in Voxel's amazing ver Voxel V1.0.4.4HF-HW is very fast compared to other implenentations any idea why it goes down and ofline so frequently? In addtion, the proposed script contained in Voxel's ReadMe that monitors the OpenVPN client connection and restarts the OpenVPN client and/or router if necessary won't run without bombing due to some syntax issue.
What am I missed here? Can someone that has this working as designed shed some light on this for me?
GiGNet
Voxel
Sorry, I do not quite understand this. What syntax issue?
Also, if you have a time, please try to check your OpenVPN client with 1.0.4.3HF version (not HF-HW). I mean stability. This version is using only asm acceleration, not hardware acceleration.
