which is most fit for WNR3500L between format .trx and .chk?
2 posts / 0 new
Phoebe
It is said that there are two kinds of format of firmware for WNR35OOL,I don't know their differences and which is the best. If I want to replace the firmware, what should I do? thanks a lot.
Subhra
As per my knowledge .chk is
As per my knowledge .chk is most fit for WNR3500L.
Can you please tell which firmware you are using presently and to which firmware you want to switch?
