I installed the latest version of Tomato on my Netgear R7000 and I cleared the NVRAM on the router and on the OVERVIEW section the Wireless disappeared for both 2.4GHz and 5GHz. It ended at LAN. Afterwars I flashed it again and checked the box that states-
After flashing, erase all data in NVRAM memory
The same thing happened. Then I flashed it again and left the box unchecked and cleared the NVRAM manually and it still occured. Right now the NVRAM isn't cleared but the Wireless is there. Is this occuring for everyone or just me? Does anyone know a fix? Thank you, any help will be greatly appreciated.
