WNDR4000 - no ethernet connectivity
3 posts / 0 new
theenglishman
Hello
I'd like to use the open source firmware on my router but I cannot connect to it and it will not connect to the internet router over ethernet.  I can connect to the wndr4000 over wireless and have upgraded the firmware to the latest version successfully.  however this made no difference.
On my laptop I get an ethernet link light
The wndr4000 shows a green solid link light.
the power light is solid green
I can conect to the admin console over wireless.  I've set dhcp on the lan and wan connections on and off, have set static ip addresses on the router and mt laptop all with no success.  my laptop cannot ping the wndr4000, even though the ip settings are correct on both ends.
tried a factory reset with no result.
short of throwing it in the bin I'm asking here to see if anyone can help.  I hope this is the right place.
theenglishman
So I'm guessing this isn't a
So I'm guessing this isn't a common issue and the unit is heading for the bin.
Shame :-(
larryb
you didnt mention what
you didnt mention what version firmware you flashed to ? after the flash did you do the 30.30.30 reset  ? If you look up how to log into the console and do a NV ram erase it may help ? And Or flash back to the factory firmware? if it does not work after its reset  maybe router is bad ? hope this helps ?
