Hey guys happy holidays I have wrote ddwrt to 7000p and it is stuck in boot loop. I have tried to reset it and try tftp but doesn't work I get TTYL=100 for a few times but when I hit to put the image doesn't work :( any thoughts guys ?
Try this: https://lancelhoff.com/how-to-fix-a-bricked-linksys-router/ although I haven't used it on R7000P it is worth a try. I unbricked others routers using this method
thank you for the reply i got the serial cable coming in next week!!!! happy new years
i got the serial cable hooking it up seeing everything in putty but however the boot sequence doesnt seem to stop when i hit ctrl+c i am using a usb to ttl converter any thoughts anyone ?
Hi the link is down any updataed link would help thanks..
