R7000P Flash from OFW To DD-WRT
2 posts / 0 new
carwash1959
Hi
After bricking my R8000 when i tried to flash Tomato firmware (Reseting every 50s) tried 30/30/30, 7s reset and nothing.
I now decided to buy a R7000P and would like update to DD-WRT, So i dont brick this on I would like some advice on how too.
My setup at the moment is:
VM HUB 3.0
My intentions are too: Flash R7000P with latest DD-WRT chk file, put VM HUB in to modem mode and use the R7000P to do all the work ie: ports and wireless
My questions are: When updating the firmware in the R7000P do I make sure that the Hub is on Modem mode already concidering that the Hub would be transmiting wireless and it may interfere with the upload of the firmware.
To setup and upload dd-wrt Firmware are the connections Ehernet from Hub (Any Port?) to internet port in R7000P?
And what will be the most stable DD-WRT for this model
All suggestions welcomed
Regards
carwash1959
Update!!
Update!!
All working with the latest DD-WRT (build 36070) including openvpn
Regards
