DD-WRT, OpenVPN Client, Android, and "Use DNSMasq for DNS" problem
1 post / 0 new
benfinkel
Hello there.
I flashed my Nighthawk to use the latest version of DD-WRT about a month ago.  I found a problem when I configured the OpenVPN client on the router.  My Android devices stopped getting internet access when it was enabled. I am using Policy Based Routing to limit the VPN to just my home PC, but the problem persisted.
After playing with it for a while, it appeared to be a DNS resolution issue.  After more searching and playing around, the solution seems to be to disable "Use DNSMasq for DNS".
Can anyone tell me if:
1) This makes sense
2) Is an okay way to configure my router
3) What in tarnation is going on?
Thanks in advance.
