cant revert to stock r9000
5 posts / 0 new
scorpio1377
scorpio1377's picture
Hello i have issue with my wifi using ddwrt so i wanted to revert back to stock. I followed every guide i have googled and it always does the same thing.
it counts down 296 sec
then it just sits there saying upgrading firmware
at the bottom left it says 1 percent uploaded
and it just sits there for more then a hour.
i tried closing page and rebooting router as well it always goes back to ddwrt.
I tried lastest firmware, also tried the firmware in download section.
I even tried tftp2 with never connect no matter what i do.
Any help would be appriciated, thanks
scorpio1377
update: i tried another
update: i tried another browswer and after 15 sec it says upgrade sucessful and reboots router but its still ddwrt.....
jfosella
jfosella's picture
Did you try a reset?
JSmith856
JSmith856's picture
same. I can't get DD-WRT off
same. I can't get DD-WRT off of my X10 R9000 back to netgear genie crap.... it takes, the file, says, "successful" but then comes back to DD-WRT.. is there a certain thing I am doing wrong??
jfosella
jfosella's picture
I've gone back and forth
I've gone back and forth twice. Both times I kept playing with the rest button. Finally after many tries it goes. I assume you already loaded
ddwrt-to-netgear-fw-R9000.bin.
