Hi, is there any experts who can confirm if the WNR3500L v2 (or the BCM47186B0 switch chip in general) in DD-WRT will support any Dot1Q VLAN ID. I've looked through quite a lot of the VLAN tagging posts and not see any with VLAN ID's below 15.
I guess because most times not many VLANs are needed in home/small offices whereas I'm wanting to put a few available WNR3500L's into an existing rather large small business network that is more a campus LAN using mostly Ubiquiti, Linksys & a few Cisco's. It already has a bunch of VLANs for other purpsoes so VLAN ID's beyond 15 is needed for the WLANs, such as 51 & 100.
I guess there is the possiblty also that the DD-WRT interface is the issue only showing VLAN ID's 1-15.
If someone knows the answer it would aid in planning if I should go down this rabbit hole :)
