Does anyone know if it's possible to run the 'Standard' edition of DD-WRT on the WGR614L router? There are some features that the micro and mini don't have that I need to use...
Not that I have seen. Only the version available here.
The flash available is 4MB on that. If you rebuild it you should be able to put it on the WGR614L, I'm not sure if you can do the same for the WGR614V8 flash though (4MB flash as well). It might require a separate build.
http://www.dd-wrt.com/wiki/index.php/WGR614_v8
http://www.dd-wrt.com/wiki/index.php/Supported_Devices#Netgear
No, the standard build will not run on 614v8. You will require to modify some part of the BSP and the flash layout as well. Some nvram attributes also needs to be changed. Download the version available here - this version incorporates all the changes required to run the firmware on 614v8.
Well Could you make a custom build that incorporates more of the features of the "Standard" version of the DD-WRT Firmware such as IPV6, SNMP, SAMBA/CIFS CLIENT, RFLOW, HTTPS Support for Web Management, and just drop the lame features too make it fit?
http://www.dd-wrt.com/wiki/index.php/What_is_DD-WRT%3F#File_Versions
we will surely try it out and let you know the proceedings..
Sounds good, I look forward to the end result.
Below is a link to the latest source code...
svn co svn://svn.dd-wrt.com/DD-WRT
For some reason he link is bad. Can you fix?
Ok, to download SVN in Windows you have to install TortoiseSVN or an equivalent.
http://tortoisesvn.tigris.org/
