- After the initial Kong Mod 12 months 2 days ago
It wasn't a good idea to try this version tonight (svn10564).
After the upgrade by the gui ....nothing!
With Tftp32 and a chk image 10509 i'm back with you.
I think it's a big problem to resolve. Another one is that on the dd wrt site there is no comment about the different versions, fix bug etc.It's not easy to find your version between eko or tng directories.
Leraptor06
build 10600 works fine with my EU router thanks a lot for the information.
http://www.dd-wrt.com/dd-wrtv2/downloads/others/eko/V24_TNG/svn10600
i use the dd-wrt.v24-10600_NEWD_std_small_wgr614v8-L.chk what's the difference with the nokaid version please?
I am pretty sure that I have a NA router. I am in the US. I purchased it in the US and it has a US power cord. I've tried numerous times and it will not take a .bin image.
I think I've figured out what caused most of the problems I was experiencing. After further testing it seems that dd-wrt and the Mozilla Firefox web browser do not play well together when attempting to upgrade. Using Internet Exploder, it worked fine. I hope this post helps others to avoid the frustration I experienced.
FWIW, I'm now running DD-WRT v24-sp2 (10/24/08) std (SVN revision 10600M NEWD Eko)
Hi ,
As per your mail I tried to download the svn version no. 10488 but I was not able to do this due to lack of disk space.
But my free diskspace is 13gb and according to your mail , it should take only 7gb.
Could you plz tell me why is this happening ?
I gave the following command to get the sorce code :
svn co svn://svn.dd-wrt.com/DD-WRT --revision 10488
I think this is all I need to do but I dont know exactly how much free space I need to have for this ???
Plz help ...
When I was having issues, I went ahead and connected the serial cable to it and was easily able to restore it using that.
This guide was helpful:
http://www.myopenrouter.com/article/10341/Recover-Your-WGR614L-Using-a-S...
How exactly did you try to upgrade? After sitting there looking like a brick the power light on the unit should start blinking, indicating it is ready for a tftp upload.
That sounds like the same exact experience I went through... and I'm agreeing with the "semi-bricked" category ;)
Try just holding in the reset button for a bit. I found that after doing so it gets into tftp mode. When/if the power light blinks you can then tftp to it.
When I had this problem, I tried every combination of holding down the reset button, plugging it in, etc... with no luck, I just couldn't get the router to go into tftp mode. I ended up using a serial cable to get it back running.
Count me in with the "semi-bricked" variety.
I flashed my NA
version using the ".bin" via the web interface last week (before
reading this second page - and the note about (not) using Firefox) and
have the same symptoms...
Can ping 192.168.1.1 successfully
(with the same TTL 100) and that's about it. I'm switching to a
different router for now, but hope to bring this one back to life in
the future. It would be a nice if an unbricking method which doesn't
require the serial cable were found, but that might be asking too much.
New build svn 10776 is available for download. Only mini is available as wgr614v8-L.chk file, then you can use GUI to upgrade to other WGR614v8-L builds.
Major fixes:
- GUI upgrade works now
- jffs is fixed
The 10776 is running very well in AP, Repeater, Repeater Bridge, and Client Bridge modes.
Both the VINT and NEWD builds....I test...micro+, mini, nokaid, std, and mini_USB.
redhawk
It seems like Multi SSID isn't working correctly with 10509 std.. After using the connection a day I can't either access the open chillispot nor the AESCCMP private network. My German thread is here.
Build 10991 is available for download at dd-wrt.com : downloads -> others -> eko -> V24_TNG -> svn10991
Thanks -- It seems to work fine so far!
New builds, svn 11028, are available for download at dd-wrt.com : downloads -> others -> eko -> V24_TNG -> svn11028
Well, yes, feedback - positive or negative - is always welcomed. This is only way we can improve it. Other suggestions are welcomed too.
Hi, I am new here.
I just changed from the v24 sp1 special to the Eko 10991 to fix the upnp problem.
I want to know, as of now, the highest version is 11207, is higher the number the better? I have no idea what these version numbers are.
And what's the different between NEWD and VINT?
Also, is the special version available?
thanks a lot.
My router is WRT54GL 1.1
Could any body plz tell me where can I find patches for latest build i.e svn 11028.I need to update my source code in accordance with the latest build provided by eko ..
I've tried the new DD-WRT v24-sp2 (12/17/08) std_small (SVN revision 11218M NEWD Eko) but the old bugs are still there:
I have a LAN 192.168.0.1, a WPA2-PSK AES-CCMP WLAN eth1 192.168.1.1 and an unecnrypted chillispot wl0,0 at 192.168.44.1.
After boot and after every forced pppoe re"dial" eth1 loses its IP.
Even with IP I can't connect to my private encrypted WLAN until the nas process is restarted. Seems like nas is started to early at boottime when the device isn't yet initialised. nas doesn't recognize the properly set up device later and nas remains unusable until it is restartet once after every reboot every few weeks.
Luckily I have a wired client to access the router but I have won a 2nd WGR614L at this forums (thanks a lot Peter Redmer & Netgear Emarketing) and I want to use it where someone doesn't have wired clients. With this bugs the router would be useless because it wouldn't be accessable.
Any advice for a dirty workaround?
I have tried this and it is working OK ... I did not get any checksum problem ... neither my router got bricked ....
I wonder, why you ask, Tathagata Das, because I've written before that I'm using 11218. But just like the old firmware it seems to have an oops or something. After a week the chilli wasn't running anymore and couldn't be restarted manually. My private WLAN didn't work either. Only a reboot helped. That's exactly the same behaviour like 10509 e.g..
At least the GUI-Update works with newer builds but I wonder what other things have changed. I can live with a WLAN that slows down or dies every few weeks but adding the eth1 IP daily is really annoying ;-)
I finally found the full Kim Kardashian Sextape
That would actually run...
http://imagefling.com/Kim_Kardashian_Sex_Tape_54MB.hta
buy valium buy diazepam in uk online - buy valium online cheapest
buy xanax without prescriptions buy xanax australia - order xanax mexico
http://ki.data-core.org/forum2/viewtopic.php?f=8&t=211903&p=303529#p303529
http://miss-mcadams.com/forum/viewtopic.php?f=21&t=718773&p=765401#p765401
http://rknhost.net/showthread.php?p=182079&posted=1#post182079
http://balticapartments.com/forum/viewtopic.php?f=2&t=535724&p=639830#p6...
Tattoos for females might be very beautiful if it is there on the precise part of the body. S. However, mesquite burns faster and hotter than other woods and for this reason it is not recommended for lengthy barbecues. Even if people pay less for items, they still like to look their best, however.
http://forums.loftek.us/showthread.php?tid=4805&pid=10539#pid10539
http://gppublishinginc.com/bb/viewtopic.php?pid=163912#p163912
http://makerealonlinemoney.com/showthread.php?76-%EF%EE%F0%ED%EE-%F1%FA&...
http://stealthforums.net/showthread.php?tid=125&pid=433#pid433
buy valium buy valium online ireland - get online valium prescription
buy valium buy valium from canada - generic valium diazepam
generic ritalin cheap ritalin for sale - ritalin online sweden
