I use dd-wrt 11218 miniBuild (2,8MB) on my 614Lv8 WW Model.
This build has no openvpn Services integrated.
Only the unsecure PPTP
Q1:
I have read, 614Lv8 WW not the NA Model can't install *.bin files with the GUI from dd-wrt.
WW 614Lv8 Model can only use *.chk files, per tftp to upgrade
Is that right?
There is no Std/smal 11218.chk in Elko's new builds, only Std/Smal *.bin for 614Lv8 .
Q2:
rename Std/smal *.bin in *.chk is that a way?
thnx for Anwers.
Greetings Teamworker
Big thx to Tathagata Das
Please read my BIG Problem under:
http://www.myopenrouter.com/forum/thread/10766/vmlinuz-Problem/
tryin to use my netgear router but lost my netgear cd
It is not clear from your post why do you need the CD .... the reset button on the board can be used to get back factory defaults .
Then you can access board's GUI at 192.168.1.1 and configure the board as per your need
