unable to ssh or telnet in - tomato
2 posts / 0 new
ear9mrn
Hi have recently installed tomato on my wgr614l nd everything is working very well. Its a great tool.
I am however having problems trying to telnet and ssh into my router. With telnet:
telnet -l root 192.168.1.1
and I get.....
Trying 192.168.1.1...
Connected to router.
Escape character is '^]'.
Connection closed by foreign host.
and in the logs i get ------  user.err telnetd: All terminals in use!
and SSH (after I copied my key which works on all my other machines)
 Permission denied (publickey).
 and the router logs.......
authpriv.info dropbear[2850]: Child connection from 192.168.1.8:45969
authpriv.warn dropbear[2850]: login attempt for nonexistent user from 192.168.1.8:45969
authpriv.info dropbear[2850]: exit before auth: error reading: Connection reset by peer
Does the owner of the key have to have an account on the router to enable login ?
How do I add a user to the router if I cannot log in. I cannot see a place to do this via the gui....
Pete.
achilles
Hi ,
Hi ,
In case of telnet it seems that you have reached the limit as far as no. of ptys are concerned.
Count the no. of ptys in /dev directory by giving the following command :
# ls /dev/pty* | wc -l
If you have reached the maximum limit then you can add new ones using the following commands :
# cd /dev
# ./MAKEDEV pty(N)
where N is a number corresponding to the pty batch:
0 = ptyp0...ptypf
1 = ptyq0...ptyqf
And for ssh plz check if you have following files or not:
/etc/nsswitch.conf and /lib/libnss_*.
all the best ...
