v11793 of DD-WRT for the WGR614L just posted!
3 posts / 0 new
Peter Redmer
Courtesy of twindragon6, this new build (both in CHK and BIN) formats) has been posted to the Downloads section.
http://www.myopenrouter.com/download/list?sort=date&cat=30
Give them a try and post your experiences here. twindragon reports that so far, they're working just fine!
achilles
thats great ... will
thats great ... will definitely give it a try ..
whosane
I just tried svn11793
I just tried svn11793 (standard no-kaid build) out and it seems to be working just great. I've got wireless and DHCP setup fine and SSH/HTTP tunneling is allowing me to surf the internet from office through the router at home.
Faced a few problems though.
1. After the setup was done and all was working fine I had turned of the router for the night. The next day all the settings were gone. I had done both a "Apply Settings" and a "Save", but it still happened. I had to put all my settings once more but since then it has't mysteriously disappeared again.
2. After a Hard 30/30/30 reset, IE would't be able to load the webui. I had to use Firefox to change the password, power cycle the router and only then does IE work.
3. The webui access is quite a bit slow when connecting from office.
Apart from that, everything is working alrite.
