very frustrated . . . simple question . . . no good answer
3 posts / 0 new
sharisax
sharisax's picture
how many computers can network on router?
I have a WNR-2000 Wireless-N Router
This works with my own laptop.
This morning I tried to network a visitor and it didn't work.
This evening, I tried a second visitor computer. This time it connected BUT my own laptop was DISCONNECTED.
I couldn't reconnect until I had turned OFF the visiting computer AND then i had to restart my own, which took a long time to re-connect because it was looking for the IP address.
Please answer this question: Should my router be able to have MORE than my main computer upstairs and my laptop downstairs? That is, can I successfully hook up three or even more computers using this router?
And if so, why did I have the problem described above?
Thank you.
below are the answers I receive thru the Forum
Now I am more confused. Your moderator did not explain things in a way I could understand.
On the link for the manual that he sent, there is NO WAN port, yet that was what I understood he suggested below:
http://forum1.netgear.com/newreply.php?do=newreply&p=191217 http://forum1.netgear.com/newreply.php?do=newreply&p=191217 http://forum1.netgear.com/newreply.php?do=newreply&p=191217
  #2   http://forum1.netgear.com/reputation.php?p=191222   http://forum1.netgear.com/report.php?p=191222
Old Yesterday, 11:19 PM
http://forum1.netgear.com/member.php?u=245
Senior Member
NETGEAR Fanatic
Mars Mug is on a distinguished road
Default Re: how many computers can network on router?
The limit is about 253 devices, but the practical limit is very much lower than that and depends on individual usage. In your case you have problems with just two PCs and I have seen this a few times in the past, the common cause being that the cable from the modem is incorrectly connected to a router LAN port instead of the WAN (Internet) port.
__________________
My name is Andy, I'm only a part time mug.
http://forum1.netgear.com/newreply.php?do=newreply&p=191222 http://forum1.netgear.com/newreply.php?do=newreply&p=191222 http://forum1.netgear.com/newreply.php?do=newreply&p=191222
  #3   Add to sharisax's Reputation   http://forum1.netgear.com/report.php?p=191272
Old Today, 08:23 AM
Junior Member
=0 9
NETGEAR Newbie
sharisax is on a distinguished road
Wink Re: how many computers can network on router?
Hi Andy [aka part-time mug], how do I know which is a LAN port and which is a WAN port?
THX for your help
http://forum1.netgear.com/newreply.php?do=newreply&p=191272 http://forum1.netgear.com/newreply.php?do=newreply&p=191272 http://forum1.netgear.com/newreply.php?do=newreply&p=191272
  #4   http://forum1.netgear.com/reputation.php?p=191286   Report Post
Old Today, 10:41 AM
Senior Member
NETGEAR Fanatic
It’s quite distinctive, labelled ‘Internet’, see pages 5/6;
ftp://downloads.netgear.com/files/WN...SM_07May08.pdf
09__________________
http://forum1.netgear.com/newreply.php?do=newreply&p=191286 http://forum1.netgear.com/newreply.php?do=newreply&p=191286 http://forum1.netgear.com/newreply.php?do=newreply&p=191286
  #5   http://forum1.netgear.com/reputation.php?p=191302   =0 A http://forum1.netgear.com/report.php?p=191302
Old Today, 11:41 AM
http://forum1.netgear.com/member.php?u=8616
Moderator
NETGEAR Fanatic
jmizoguchi is on a distinguished road
http://forum1.netgear.com/showthread.php?t=38612&highlight=sharisax#
09
Quote:
Originally Posted by sharisax http://forum1.netgear.com/showthread.php?p=191272#post191272
THX for your help
you have to be blind to get lost on that...
N router would bad choice for hot spot for other than who uses more often.
that is one reason20you do not see N access point in free wifi hot spot in business. more likely combination of wireless model and encryption.
this something you need to play with it to find out for each person who has issues
achilles
achilles's picture
It is not clear from your
It is not clear from your post whether u want to connect them through wireless or through ethernet ... However from the following quotes in your post :
"Please answer this question: Should my router be able to have MORE than my main computer upstairs and my laptop downstairs? That is, can I successfully hook up three or even more computers using this router?"
I guess it z a wireless connection .. if it z wireless connection plz check if all the wireless clients r using the same parameters (such as channel, mode , security keys etc.) ...
For connection thru ethernet it shud not be aa prblm ...
Do let me know if u need any further info ...
thnx
sharisax
sharisax's picture
thnx
Thanks, Achilles, but I got SO FRUSTRATED, I just returned the Netgear and bought Linksys instead and now everything works
