Have anyone try to compile the source code under ubuntu? and what version of ubuntu did you used?
- R8000P would be grate to see. 1 year 14 hours ago
- Have a R8000 but ordered a 1 year 14 hours ago
Hi, I did tried it with ubuntu 8.10 and I get some mipsel-uclibc-gcc error. Something like /bin/sh: mipsel-uclibc-gcc: command not found.
How can that be worked around
I have install/copy/put the chaintool into /opt/brcm.
I am still not sure what is thsi chaintool.
Recompile the code and I get the below error
make[2]: Entering directory `/home/tuck/Tomato/bcm5354/src/router/www'
rm -rf /home/tuck/Tomato/bcm5354/src/router/mipsel-uclibc/install/www/www
mkdir -p /home/tuck/Tomato/bcm5354/src/router/mipsel-uclibc/install/www/www
cp *.gif *.png *.ico robots.txt /home/tuck/Tomato/bcm5354/src/router/mipsel-uclibc/install/www/www
for F in *.{js,jsx}; do \
sed '/^\/\*\s*$/,/\*\//! { s/^\s\+//; s/\s\+$//; /^\/\/ --\+\s*/d; /^$/d }' /home/tuck/Tomato/bcm5354/src/router/mipsel-uclibc/install/www/www/$F; \
done
/bin/sh: cannot open *.{js,jsx}: No such file
make[2]: *** [install] Error 2
make[2]: Leaving directory `/home/tuck/Tomato/bcm5354/src/router/www'
make[1]: *** [www-install] Error 2
make[1]: Leaving directory `/home/tuck/Tomato/bcm5354/src/router'
make: *** [all] Error 2
Can anyone share the light on this?
Hi, Thanks. I finally got it to compile. But under the /src/image directory I don't see the tomato_wgr614l.chk file. I only get the below
-rw-r--r-- 1 root root 2674688 2009-03-15 14:16 tomato.trx
-rw-r--r-- 1 root root 2674696 2009-03-15 14:16 WR850G.bin
-rw-r--r-- 1 root root 2675712 2009-03-15 14:16 WRT54GS.bin
-rw-r--r-- 1 root root 2675712 2009-03-15 14:16 WRT54GSv4.bin
-rw-r--r-- 1 root root 2675712 2009-03-15 14:16 WRT54G_WRT54GL.bin
-rw-r--r-- 1 root root 2675712 2009-03-15 14:16 WRTSL54GS.bin
Thank you.
You can at least try it and share your experience with us. If you face any problem then I will install Ubuntu (same version that you would use) in my machine and try to compile that code.Really i am impressed from this post....the person who create this post he is a great human..thanks for shared this with us.i found this informative and interesting blog so i think so its very useful and knowledge able.I would like to thank you for the efforts you have made in writing this article. I am hoping the same best work from you in the future as well...
http://www.bingoonlinefree.net
