Hi
Coupple days ago I started to compile my own tomato for ovslink WL-1600GL. The firmware works almost ok, but still few thing has to be done. First of all which file I need to edit to change VLAN configuration ? I need to change it because every time I flash the router I have to set proper vlans like this:
nvram set vlan1ports="4 5"
nvram set vlan0ports="0 1 2 3 5*"
nvram set manual_boot_nv=1
nvram commit
The second thing is GPIO's, which file I need to edit to set them properly. I would be very gratefull for all help :)
Thanks, but I have already finished :)
Here is the tomato 1.27 firmware for WL-1600GL.
http://rapidshare.com/files/314695591/tomato-ND-1_27.trx.html
-All GPIO leds works ok
-JFFS2 works
-setting proper mac addres works
-vlan works out of the box
-WPS works
-reset switch works
release/src/router/shared/led.c
