DD-WRT No Internet
22 posts / 0 new
Anonymous (not verified)
DD-WRT No Internet
Hi, Recently I've Upgraded My Buffalo WHR-G125 From Tomato Firmware To DD-WRT and since that i can't get on the internet my networks goes
BT Home Hub ------Computers
Buffalo
Computers
Please Help, I've Read Other Posts About Changing The Routing To Router From Gateway, But That Doesn't Work, And I've Tried Changing The MAC Address as well
Jamie
buddee
what kind of isp is it? DSL
what kind of isp is it? DSL or cable? also when your doing this you need to have your router coming off of the modem be it cable or DSL. you may have to use the mac address cloning so you have the mac that orginally setup the internet service. release then renew all of your DHCP records as well.
It's Bt On DSL, goes from
It's Bt On DSL, goes from Phone Line To Home Hub Then To Buffalo, i tried Mac Address Cloning Thats No Help, And I've Tried DHCP Renewing and Releasing. I Don't Want To Back To Tomato As DD-WRT Has More Features :/ So Unless I Can Fix It I'm Going To Have To Go Back To Tomato
buddee
Buffalo
Computers
Jamie
The scematic you posted shows BT Home hub, is this the DSL modem? If so is it a router/modem combo?
jamidodger1 (not verified)
Yes It Is A DSL Modem And Yes
Yes It Is A DSL Modem And Yes It's A Router/Modem Combo. And I've Already Tried Mac Address Clone and Changing The Setting To Router, Not Gatway
Hands of Blue
Did you follow the 30-30-30
Did you follow the 30-30-30 reset?
I've got the same unit running DD-WRT without problems, so it'll work. Is it picking up a WAN IP address from the HomeHub? Are you using a different IP range on the LAN interface of the G125 than on the HomeHub? Have you left the G125 doing NAT?
its picking a wan ip up, The
its picking a wan ip up, The Range on HomeHub Is 192.168.1.---
and Buffalo Is 192.168.1.100 and on, does this need changing? how do i change the NAT feature?
Hands of Blue
Is 192.168.1.100 the WAN or
Is 192.168.1.100 the WAN or the LAN IP of the Buffalo? If it's the WAN then you've nothing to worry about. If it's the LAN then you must change it (I'd suggest something like 10.168.1.1 with a netmask of 255.255.255.0).
As for NAT, if the version you're running is similar to mine then it'll be under
Setup
then
Advanced Routing
. Make sure the mode is
Gateway
Shouldn't It Be Router Not
Shouldn't It Be Router Not Gateway As I Use The Bt Home Hub To Connect To The Phone Line?
IP Address:
Buffalo WAN IP: 192.168.1.64
Buffalo DHCP IP: 192.168.1.100 START
Router Ip
Buffalo local ip address: 192.168.1.1
Buffalo Subnet Mask: 255.255.255.0
Buffalo GateWay: 0.0.0.0
Buffalo Local DNS: 0.0.0.0
Hands of Blue
In Router mode it doesn't do
In Router mode it doesn't do NAT, which will be the source of some of your problems.
Your other problem is that you are using the same IP range for both networks. You must not do that.
Set the WAN on the Buffalo to DHCP. Then set the LAN as follows:
Local IP Address: 10.168.1.1
buddee
Also as i said, IMHO the
Also as i said, IMHO the better setup is if you turn off all of the routing in the DSL modem, let it just be a modem, and let the dd-wrt router do all the routing, you can hub off the router and would not have to do A and B class ip's should you need a list of A and B class subnet's and ip's i can post those as well.
Hands of Blue
Given the nature of the
Given the nature of the HomeHub I don't think you can make it dumb modem - it's an all in one DSL router with WiFi and a cordless phone.
Hands of Blue said:
Yes It Is All In One, And The Router Setup Page Is Just Rubbish
Nope I Tried Setting It To
Nope I Tried Setting It To Gateway And Changing The IP Address's To What You Said And It Didn't Work :( , Is It possible to send me your dd-wrt settings file?? And See If That Works Or Not?
Yes!!! Got It To Work, I
Yes!!! Got It To Work, I Changed My BT Home Hub Settings From 192.168.1.--- to 192.168.0.--- and changed buffalo to 192.168.11.--- and it works fine :D Thanks For All Your Help
Jamie
Hands of Blue
As I'll be running a
As I'll be running a different version (it's quite old) that wouldn't be advisable and would probably make things worse.
I assume you remembered to Save and then Apply the settings when you changed them?
So, in order:
1) If you SSH onto the Buffalo, can you "ping" the IP address of the HomeHub?
2) From a PC behind the Buffalo, can you "ping" the IP address of the HomeHub?
Hands of Blue
Excellent - glad it's sorted
Excellent - glad it's sorted now.
One Last Thing I Don't Know
One Last Thing I Don't Know If I Should Add It On Here, If I Use It as a Client on the wireless i connected it to my bt home hub thats all ok, but i can't use the internet what do i need to set up? Is There A Tutorial For It??
Hands of Blue
Are you trying to say that if
Are you trying to say that if you connect to the Buffalo via wire you can connect to the Internet, but if you use Wireless you can't? What is the "It" you refer to ("If I Use It")?
buddee
Ahh i then stand corrected
Right Ever Thing Is Fine
Right Ever Thing Is Fine WIRED But If I Put The Buffalo Into Client Mode.
It Connects Fine, I Just Cant Use the Internet When Its In Client Mode And Yes I've Plugged An Ethanet Cable Into It to my pc
Hands of Blue
Are you trying to use the
Are you trying to use the Buffalo as a wireless connected router (which is what client mode is for)? You're aware that in client mode it doesn't allow connections to it as a wireless access point?
Did you read the Wiki on Client mode (http://www.dd-wrt.com/wiki/index.php/Client_Mode_Wireless)?
