I needed to create an internet connected public network using a single router (WNR-3500L w/ DD-WRT on it) and had to isolate it from a private network running on the same router. I found a set of instructions on the net for a different router but had to modify them some for this router.
It took a bit of playing with, but I got it to eventually work. I felt compelled to share my method - so I wrote a post up on my site.
http://aaka.sh/patel/2011/07/17/creating-isolated-vlan-ddwrt-wnr3500l/
I've tested the instructions on more than one occasion (thanks to a few typos while setting nvram variables doing other tinkering resulting in resets :P)
Enjoy!
-Aakash Patel
That's pretty cool. I don't have a need to create a private network like that now but if/when I may need to do so, using your info, it makes it real easy.
Thanks for sharing it!
Thanks. Is it possible to have two DHCP server which release different segment ip on 2 network segments?
