You want to use one of the normal builds like:
Tomato-K26USB-128.7475MIPSR2-Toastman-RT-Ext.trx
The NVRAM60K has to do with block sizes in the NVRAM. Some versions are specific to a router type, thus the E4200 prefix.
The items at the end (Ext, Lite, VPN, and VPN-NoCat designate subbuilds. You can look at http://tomatousb.org/doc:build-features-cross-reference to get summary of the different build features.
Personnally, I use Tomato-K26USB-128.7475MIPSR2-Toastman-RT-VPN-NoCat.trx on my own 3500L. It has essentially everything rolled into the firmware. If you think you might not use the VPN or the portal capture feature, the normal -Ext version runs just fine on your router.
Thanks for your help, i'm aware of the different builds but i couldn't find any info on the NVRAM60K builds. I currently run a Ext firmware, but i would like to upgrade to a VPN build but got confused at the amount of builds there are. Thanks again! :)
