I was so exicited to flash that I forgot to make a backup of the Netgear stock firmware, I need to send it in to get replaced and wanted to put the stock firmware back in. Not sure on how to do this, so any help would be greatly appreciated!
http://www.downloads.netgear.com/files/GDC/R7000/R7000_V1.0.3.24_1.1.20.zip
Please mention which firmware you are using currently in your R7000.
it shows me that I am using firmware DD-WRT v24-sp2 (02/13/14) when i put the netgear firmware in after reboot it shows me that I am using the dd-wrt firmware and only gives me the dd-wrt interface!
Are you sure you uploaded the correct chk? DD-WRT might accept a fw image and tell you that upload was complete, but if the image was not for this model it will stop flashing and just reboot.
I thought that I did, do you know which one I should use? I got it from the netgear site. It should have been the right one
