USB HD mounted but not seen in File Sharing Path
5 posts / 0 new
lavalamp
Current Firmware: DD-WRT v24-sp2 (03/23/14) kongac
I have a Seagate Backup Plus 3TB HD. I see the following in disk info:
--- /dev/sdb
Block device, size 2.729 TiB (3000592977920 bytes)
DOS/MBR partition map
Partition 1: 349.3 GiB (375072489472 bytes, 732563456 sectors from 2048)
Type 0x07 (NTFS/HPFS)
/dev/sdb not mounted Unsupported Filesystem
--- /dev/sdb1
Block device, size 2.729 TiB (3000579915776 bytes)
Windows NTLDR boot loader
NTFS file system
UUID 26BCAD5BBCAD2671
Volume size 2.729 TiB (3000579911680 bytes, 732563455 sectors of 4 KiB)
/dev/sdb1 mounted to /tmp/mnt/sdb1
Sometimes the first partition does not show up and only the mounted one is listed.
When I try to add this path to NAS -> File Sharing it is not listed in the dropdown.
I have a 1.5TB Samsung HD that has no issue being mounted and shared. Both drives mounted and shared correctly on the stock Netgear firmware.
Any ideas? Will I likely be forced to reformat my drive?
Kong
Although I didn't have any
Although I didn't have any issue with the bunch of drives I tested. A handful users reported the same problem. For the next build I'm adding a little delay to give problematic drives a chance to be ready when mounting starts.
Watch out for a new build. I'll add it to my changelog.
lavalamp
Thanks for the reply. We are
Thanks for the reply. We are very lucky to have your continued development!
Kong
By the way, in latest build I
By the way, in latest build I added some delay and another user that was affected by the same issue confirmed that is is working now.
lavalamp
Perfect! Confirmed working on
Perfect! Confirmed working on my Seagate Backup Plus 3TB.
