What is the difference between STD & BT and OLDD & NEWD
3 posts / 0 new
Wolfeman0101
I am planning to flash my R7000 with dd-wrt.v24-K3_AC_ARM_STD_OLDD.bin but I'm not sure if that's the right of the 4 options.  What are the differences and which is best?
AnshJ
Directly from Kong, http:/
Directly from Kong, http://desipro.de/ddwrt/K3-AC-Arm/r23884/Supported%20Models%20-%20R6250%...
This should tell you the difference between them, as for what's best.. I guess that depends on what you want.
Wolfeman0101
Thanks for the link, I couldn
Thanks for the link, I couldn't find it.
