What is the difference between STD & BT and OLDD & NEWD
I am planning to flash my R7000 with dd-wrt.v24-K3_AC_ARM_STD_OLDD.bin but I'm not sure if that's the right of the 4 options. What are the differences and which is best?
Website security can be a complex and even confusing topic because of its ever-evolving landscape, for that reason, it’s important to keep in mind that security (especially website security) is never a set-it-and-forget-it solution.
Why is website security important?
Directly from Kong, http://desipro.de/ddwrt/K3-AC-Arm/r23884/Supported%20Models%20-%20R6250%...
This should tell you the difference between them, as for what's best.. I guess that depends on what you want.
Thanks for the link, I couldn't find it.
