I just put both sets of code into the Startup Script and LAN 1 is still illuminated. Maybe its becuase its connected at 100MBps, or is its missling a line?
Any advice would be much appreciated.
Please run the following scripts on boot via startup script or terminal:
logger "Disabling LED Lights: Step 1"
# add this to your startup script to disable the lights on your r7000.
for i in 2 3 8 9 12 13 17 18 ; do gpio enable $i ; done
for i in 14 15 ; do gpio disable $i ; done
logger "Disabling LED Lights: Step 2"
# Run this from the command line to disable the 4 LAN lights.
et robowr 0x0 0x18 0x1ff
et robowr 0x0 0x18 0x0
et robowr 0x0 0x1a 0x0
I put in here, click apply, but after a reboot, nothing happen :(
It's wrong?
Sorry, i press Run Commands, there are not Apply ;)
Router does not recognize these commands -
Can anybody tell the right commands ?
Is step two maybe missing a line?
