Firmware R7300DST
6 posts / 0 new
HuuNguyen
Firmware R7300DST
Hey everyone,
I had bought a Netgear Nighthawk R7300DST a several days ago. Can I use open source firmware R7000 or R7500 for R7300? Because I want to use bridge mode or Vlan tag group (Vlan/IPTV set up). Howevers, when I use this function, it doesn't have internet.
Thanks for watching.
Nguyen
pcs305
I'm also looking into
I'm also looking into replacing stock software with opensource.
This is what I see for the AC1900 DST  - R7300
CPU : Broadcom BCM4709A
2.4 GHz : Broadcom BCM4360
5 GHz : Broadcom BCM4709A
leb686
Is anything under development
Is anything under development to enable the R7300DST to be flashed?
gwlawson
Ditto leb686
Ditto leb686
Any intended releases for Netgear R7300? Will not work with R 7000. Any thread about Kong and 7300
gwlawson
2016.08.26. Friday 12:11:   re:  dd-wrt  by Kong wrote  R7000 build won't work on the R7300,
<Kong>
DD-WRT GuruJoined: 15 Dec 2010Posts: 3146Location: Germany
Posted: Mon May 16, 2016 21:06 Post subject:
Since I received a bit of debug info from a R7300 user. I can confirm that, the R7000 build won't work on the R7300, burning the R7000 boardid to the R7300 can permanently damage yourunit. Unlike the R6700 which is identical to the R7000, this unit has a few differences that require proper detection+ customization. A sample unit is required in this case.
_________________KONG PB's: http://www.desipro.de/ddwrt/
gwlawson
See:  http://www.dd-wrt.com/phpBB2/viewtopic.php?t=300470&highlight=r7300
