Wireless AC option not available on my R7000 with advanced tomato installed
7 posts / 0 new
csheehy
csheehy's picture
I cant select an option to choose AC wireless for the 5Ghz Wireless. Im running the latest advanced Tomato. I only have the option For Wireless A & N. Anyone had this issue?
zako93s
zako93s's picture
Try to set your country on WiFi settings to SINGAPORE.
Cheers
maupicc
maupicc's picture
I also don't see AC option
I also don't see AC option even using SINGAPORE..
Any idea??
tomski182
tomski182's picture
It's also missing for me
sesser
sesser's picture
According to Netgear...
IMPORTANT
WPA-PSK [TKIP] may only operate at legacy rate, not N or AC rate.
NETGEAR recommends that you use WPA2-PSK [AES] to get full N or AC rate support.
I take this to mean if you use TKIP, you don't get full speed of AC (1300 in this case) and reverts to 600. This is an alert when choosing "WPA-PSK [TKIP] + WPA2-PSK [AES]"  in the Netgear genie interface
ahnfire
ahnfire's picture
I also face the same problem
I also face the same problem as the original poster. I am using WPA2/AES only. I try to set it to 80, but it reverts to 40. I am using 138 AIO
ahnfire
ahnfire's picture
Ah ha... I figured my problem
Ah ha... I figured my problem out. Leaving the channels as Auto prevented it from going to 80. I selected one of the choices and now it's running at 80. I hope that helps you.
