- I think the R8000 firmware 4 days 1 hour ago
- Just want to add some update: 5 days 19 hours ago
- When I press Ctrl+C, the boot 5 days 21 hours ago
- Well, Netgear has the 1 week 17 hours ago
Good evening , I would like to know the default password . I can not log in anymore . I tried to do a hard reset with 30/30/30 and proven method to enter username root password admin but does not access .
Hi magonero, the default login should work, but if it does not try "admin/admin" or "root/root" or other variations which may work. I'll ask Kong if the default password is different on any of the releases.
Also, Kong's releases should prompt you after the update completes for you to specify a new password. If you perform another reset and make sure it worked, then you should actually be able to specify the password you want to use.
If you are logging in via telnet, it's root/admin
Well this firmware works flawlessly much better than the original one...
For non broadcom models as the R7500v2/R7800 you need a modified netgear image which can be flashed directly through dd-wrt webif
Kong sir.. I installed the fw for r7500v2. So far running good.. Question.. Tried to use NAS..cant open the folder that i named.. I can see it throuh my network but when i open the folder it wont let me.. Thank you for any info
Kong - I have tried multiple times reverting to netgear firmware using the instructions as outlined in the readme. I have downloaded the appropriate file ddwrt-to-netgear-fw r7500v2.bin. I have used the regular ddwrt webif in the firmware area to upload this file to revert back to original FW. However, in the process, every single time around 10 seconds into it or less, it immediately says "Update Successful -- Rebooting Router" and upon reboot it immediately restarts with dd-wrt interface and nothing has been changed.
I have tried several times without avail, each time same issue. I have tried using Chrome / IE / Firefox. Same issue.
Any advice you could provide would be greatly appreciated. I am not a technical expert by any means but very familar with flashing hardware devices and using non-stock firmware. To be honest my internet speed drop dramatically using this firmware (50 mgbs -> 7 mgbs), so right now I have given up reverting and using an older TPLINK router I had upgraded from and it is running normally. I really wanted dd-wrt to put in restrictions on my network by MAC address ...
Thanks for your help and support.
I'm geting the same issue, unable to revert back to the stock firmware
Again. Same issue.
can someone assit me with the default username and password for the Kong image for R7800? I have tried everything I can find such as admin/admin, admin/password, root/root, root/admin, root/password and even my own password. Please assist.
waste of time
