What's at the end of the rainbow?
If you were hoping for an actual pot of gold, we're sorry to disappoint you. However, those of you using Kong's DD-WRT firmware on your NETGEAR router, then you're in luck.
Kong's March updates have been posted to our downloads section -- update now, or give them a try!
Category:
What's the changes in this version?
with the March upgrade of my R8500 my 2 vonage boxes stopped working not able to pull an IP from the R8500. any idea hw I can fix it? or what do I have to do to go bck to the January version?
Where can we find the patch notes? I would like to update my router although i like to make it a habit to read an new update's notes to see what all has changed.
Can somebody point me towards the right direction? Sorry if they were staring me in the face, i just couldnt see them
Latest version (31800) fails for a very specific case for us on an R6400. Cisco VoIP phone model SPA525G2 does not get a DHCP response back, for some reason. It also fails on 31500. Downgrading to 31205 works fine.
This is with a pretty generic configuration with no VLAN or other "weird" networking configuration.
Looks like you're seeing the same problem we are (maybe). Cisco VoIP phone doesn't get a proper DHCP response back from the router. Downgrading to 31205 worked for us.
I have a Netgear AC1450 running DD-WRT v3.0-r31160M kongac (01/18/17) downloaded from MyOpenRouter. Is it safe to install this March 2017 Kong Mod? Or should I wait for a specific Kong Mod for the AC1450?
Netgear R7800 running build 31815m
I cannot change the SSID name. It stays at dd-wrt. Is there a way to make the name change permanent?
