No Internet after DD-wrt Flash
5 posts / 0 new
Potterman210
Hello, very new to all of this.
After succefully flashing my R7000 router to the latest dd-wrt Kong version posted(Monday, May 22, 2017), I have no internet access. I reflashed my old netgear firmware and it works fine (provides internet).
I followed every step from this link but do not know what to do from here, could someone please help me troubleshoot?
https://www.tweaking4all.com/hardware/netgear-r7000-dd-wrt/
Potterman210
Man these forums are pretty
Man these forums are pretty dead...
Potterman210
SOLVED
SOLVED
I did a complete power cycle on the modem and router ---> hardreset the router by pressing the reset button for 30seconds (this gave my router internet, but no internet access)
I had to clone my modem's mac address into the WAN section of the router setup. After plugging directly from my modem to my laptop, I found the address "network and sharing" ---> "Change adapter setting" ---> right click the "Ethernet" adapter ---> "Status" and copied the "Physical Address" value.
Shout out to the Netgear guru who helped me over the phone
Cinghialino
Tahnk you for your solution.
Tahnk you for your solution. I have your same problem and I'll be go into details soon to solve it. Thank you again.
Cinghialino
just for curiosity, why did
just for curiosity, why did you had to clone your modem's MAC address?
