Partial initial flash
2 posts / 0 new
kmerrick
Not sure how but I am stuck a the initial tomato firmware with no options to go further.
Scenario:
Running Advanced Tomato, flashed back to ofw (all is well), upgraded genie then flashed tomato-R7000-initial.chk
Now i am stuck.  I can telnet and winscp but can not successfully tftp or tftp2 (from netgear site).  Can I manually send the firmware over via WinSCP and continue somehow?
I can't post images .... so this is the best I can do. The config page is clickable but nothing can be done Save/Cancel.
!! Attention !!
You did not configure TomatoAnon project setting.
Please go to TomatoAnon configuration page and make a choice.
System (hide)
WAN (hide)
LAN (hide)
kmerrick
Was able to SCP the R7000
Was able to SCP the R7000-back-to-ofw.trx and flash via telnet
mtd-write2 R7000-back-to-ofw.trx linux <return>
mtd-erase2 nvram <return>
reboot <return>
go into Genie, clear defaults then start process of Tomato install from scratch.  Absolutely NO luck with tftp
