DD-WRT "Kong Mod" vs. Voxel's version & best settings
9 posts / 0 new
kinakuta
Hi everyone,
I just got my R7800 to use it as my VPN router (client & server) and flashed it with the "Kong Mod". Everything works just fine, great version.
Then I saw that Voxel has compiled his own version and everyone's raving about that one.
So how do the two compare? Why should I prefer Voxel's version over the "Kong Mod"?
And as a second question, does anyone have a list of general router settings to improve the speed, i.e. TX rate, QoS, Multibeaming etc.? I'm not a gamer, but I do use video streaming and all the other usual things.
Best,
Martin
Voxel
Perhaps most short answer is here (DD-WRT forum):
https://www.dd-wrt.com/phpBB2/viewtopic.php?p=1068672&sid=edf4c2de108acf...
(at the bottom of page). If you need more advanced functionality which could be set from GUI then DD-WRT. If speed first of all then my build (hardware acceleration).
I do not have OpenVPN client yet, only plans:
https://www.snbforums.com/threads/custom-firmware-build-for-r7800-with-o...
kinakuta
Hi Voxel,
Hi Voxel,
thanks for your reply. I'd love to use your firmware version, but I do need an OpenVPN client. I would be more than happy with a really simple config option, even just copying the ovpn file via SSH / Telnet, as long as there's an OpenVPN client running that I can use.
Since I'm very familiar with different Linux flavors I wouldn't have a problem manually configuring everything. But I guess for most people some sort of GUI would be preferable. But maybe a simple GUI accessible through a local webserver at a different address / port would be an alternative if you can't change anything in the official GUI.
Overall I'm sure everyone would love the combination of an optimized stock firmware and an OpenVPN client.
Best,
Martin
onebadazzmf
This is new to me... coming
This is new to me... coming from asus routers. I have 7800 how do I install the voxel firmware
Voxel
onebadazzmf:
onebadazzmf:
Just download it and install from the stock WebGUI. Nothing special is needed. If you need additional features, please read my readme.docx
Dmitry Zhuravlev
Hello! tell me where to get
Hello! tell me where to get the firmware ddwrt-to-netgear-fw-R7800.bin ?  According to the links got 403 forbidden while accessing http://www.desipro.de/ddwrt/K3-AC-IPQ806X/.......If not hard reset on the mailbox [email protected] thanks in advance!! sorry that is not the topic. But I can't find this firmware to put Voxel
BrandonForcey
HI there guys, very new here,
HI there guys, very new here, managed to load kongs dd-wrt onto my R7800 last week, and so far im not that impressed, wifi speeds have been all over the place and just hasnt felt stable, I tried changing to LEDE but that was a fail and have no idea how to change the firmware back, I'd like to possibly try out voxels, can you give me some quick pointers how to quickly change to this firmware instead???
MrMad1966
Flash back to stock using
Flash back to stock using ddwrt-to-netgear-fw-R7800.bin. then flash Voxels image
alex1888
My son gave me his r7800
My son gave me his R7800 which is flashed with DD-WRT v3.0-r29695M  as i have no idea how to set this up is it possible to restore factory setting. I have tried ddwrt-to-netgear-fw-R7800.bin but when i check http://192.168.1.1 it still shows dd-wrt not netgear. as you can tell im clueless on this subject i would be appreciate any help
