I've flashed many routers with dd-wrt and was this time I was working on a brand new R6300v2.
Has anybody seen this problem.
I successfully flashed the latest Kong Mod 2017-06-11 dd-wrt.K3_R6300V2.zip. Everything was working properly until I changed a wireless WDS config and rebooted.
The router became unresponsive and I can no longer connect, even after attempting a 30/30/30 reset.
I have attempting to re-flash the firmware using TFTP but it is also failing with server not responding.
When I reboot (power down/up) the router i see the netgear logo and it is quickly followed by a brief showing of the amber light and blue wireless & USB lights, then the blue lights go off.
Then, with only the amber light on, I am able to get a ping response from the router at 192.168.1.1 with a TTL=100 response, but that lasts for only 20 pings before timeouts.
This cycle is consistent regardless of which version of tftp (or tftp2) is use, what firmware I attempt to flash (stock, dd-wrt, tomato), and what ever PC I used (Windows 10 / Windows XP).
After the ping stops responding, the amber light stays on for a while, then the netgear logo blinks and the amber light turns solid green.
Can anybody suggest any other fixes before I shop for a USB cable?
I was able to bring it back to life using the process of flashing vmlinuz developed by Sploit and described at www.dd-wrt.com http://www.dd-wrt.com/phpBB2/viewtopic.php?t=304398&postdays=0&postorder...
I'm now back on the same version of dd-wrt v3.0-r32170M (06/11/17) and will report back if it locks me out again.
There is lots of great information out there.
