I'd like to be able to create and use a guest network with the R8000 in AP mode. Based on my research, it sounds like a Tomato install might do this, but I'm not sure.
I've had some experience with dd-wrt and guest networks and it wasn't very positive.
But maybe more importantly, does anyone know if a guest network requires a specific mode on either Tomato or dd-wrt? The stock (OEM) firmware must use Router mode, not AP mode to do this and that doesn't work in my network.
Essentially, I want to be able to use the device to do the following: create and manage a guest network, provide wireless and wired access to clients (no nat, no firewall). For Internet access, the device connects to a dedicated router that connects to a dedicated firewall and from there data goes to the Net. The firewall handles NAT and some routing.
Is this doable in any other mode than Router on either dd-wrt or Tomato?
Well Kong has a wonderful tutorial you can do a quick search for. Assuming your using Netgear and DD-WRT. I have it running on several offices.
