Hello!
I am struggling to disable all the led lights on the Netgear R7000P router.
I have been looking around the internet and on formums but I haven't found a single solution (e.g. startup script) that worked for me.
I am runnning firmware: DD-WRT v3.0-r33675M kongac (11/03/17)
Does anyone have a working solution for this?
This worked by saving it into the startup scripts under Administration/Commands!
It also disables the LEDs for the USB drive, which is nice.
Code:
#!/bin/sh
for i in 2 3 8 9 12 13 17 18 ; do gpio enable $i ; done
for i in 14 15 ; do gpio disable $i ; done
et robowr 0x0 0x18 0x1ff
et robowr 0x0 0x18 0x0
et robowr 0x0 0x1a 0x0
I just tried this an it works...
Mmh...when running the commands I get this error: sh: eval: line 7: syntax error: unexpected end of file (expecting ø~°xø~donet;
Any ideas?
