First off, all of my LAN ports are bad. So I can not connect via a hardwire. I was trying to convert to a wireless range extender. I managed to download and install the latest dd-wrt firmware. However, when I try to connect via WIFI to dd-wrt it is requesting a WPA2 password. I also tried 30/30/30 with the same results.
Any suggestions?
Hi did you ever figure the password? I got the same problem here.
Ditto, same problem. Undocumented any fucking where. Maybe my swear will attract attention to this issue
same pb
found: same like written under router: mo*********h809
