Stock Firmware for R6400v2
7 posts / 0 new
blueeyiz702
blueeyiz702's picture
Here is link for stock firmware for netgear r6400v2 if you need it.
https://www.netgear.com/support/product/r6400v2#Firmware Version 1.0.2.44cool
koopatroopa
koopatroopa's picture
How would I go about flashing
How would I go about flashing this back on my router? I downloaded it and tried through dd-wrt, but it didnt work.
dimomitev
dimomitev's picture
I need stock firmware too
I need stock firmware too because of warranty ishu!
Please help!
TXUSA
TXUSA's picture
You can't flash that back
You can't flash that back onto the 6400v2 because the firmware file that Netgear posted doesn't work. I already told them but they haven't fixed it until now. The board ID that tells the router that the firmware is the right one to flash on the router is incorrect, therefore it can't be flashed back on the router.
TXUSA
TXUSA's picture
I should say, they haven't
I should say, they haven't fixed it so far. Grammar. Grammar.
dimomitev
dimomitev's picture
Thank you TXUSA!
Thank you TXUSA!
There is a new build BrainSlayer ftp://ftp.dd-wrt.com/betas/2018/06-16-2018-r36154/netgear-r6400v2/
Is it posible to directly flash this build ?
I want to test it.
TXUSA
TXUSA's picture
If you have DD WRT on your
If you have DD WRT on your router currently... yes you should be able to upload it though the DD WRT interface
