Nighthawk AC2300 R7000P
6 posts / 0 new
rjmac681
Just want to make sure this is done right without bricking my router...
This is the right DD-WRT firmware download file right?   https://www.myopenrouter.com/download/dd-wrt-netgear-r7000p-rev-30776-20...
Is there a CHK file that I should be using after this? If so which one...
Just bought this router a couple of weeks ago...
Thanks and much appriciated
TXUSA
I personally prefer Kong's
I personally prefer Kong's builds (they are usually stable and well tested). You can flash this chk file right from the Netgear firmware upgrade page.
http://desipro.de/ddwrt/K3-AC-Arm/dd-wrt.K3_R7000P.chk
rjmac681
Thank you TXUSA, I will use
Thank you TXUSA, I will use try this...
joe 9804
I had the same question in my mind. So I visited Netgear Customer Support
. They give me the proper answer. So guys also visit them and they will give you a proper solution for your queries
<a
href="https://netgears.support/netgear-router-support-usa/">netgear
router support usa</a>. They give me the proper answer. So guys also visit them and they will give you a proper solution for your queries
abraham
Hi everyone: I need a little
Hi everyone: I need a little explanation of terms to understand which version of DD-wrt does what and why the differences? For example , what is the difference between STD.BIN and STD.BIN.MD5, STD.BIN. SIG, STD.128K.BIN, or STD.128K.BIN.MD5.
This may be too basic a question but for a newby this is a herd nut to crack. Please help
lordtamo
consider that md5 files are there to check that your main files are not corrupted.
It 's a checksum.
Take a look at wikipedia md5 page to understand how it works.
regards
