I really want to try this firmware, but I just bricked my R8000. Waiting on my usb to Tyler cable so I can unbridrick it
us there a specific order I need to flash? I flashed back to stock, reset back to factory,
then flashed the chk file above for 7.9. Wouldn’t boot up and couldn’t recover with tarp...
what did I do wrong?
thanks!
I really want to try this firmware, but I just bricked my R8000. Waiting on my usb to TTL cable so I can unbridrick it
Is there a specific order I need to flash?
What I did was...
then flashed the chk file above for 7.9. Wouldn’t boot up and couldn’t recover with tftp...
thanks!
I thought I had bricked my R8000 when I tired this firmware ahwile back.
It was just when factory reset the LAN ports didnt work and the router had changed to a 192.168.50.1 address and I could access it only over WiFi.
I also cant get the settings to stick once setup and the router is powered down, it seems to revert back to factory settings, also noticed the later versions of the FW also have cut back most of the Asus-Merlin features like QoS and traffic history does anyone have a way around this other than use the earlier FW?
@ dkopsieker
Did you flash the initial firmware 1st?
You cannot go from Getgear's Genie to Asus( Koolshare) without flashing the initial because the framework is totaly different, and results in a guaranteed brick.
From stock 1st flash: R8000_380.63_2-X7.2.1.chk
And from there you can flash any other version.
If you need to go back to Netgear, flash the special made firmware.
All can be found here: http://firmware.koolshare.cn/Koolshare_Merlin_Legacy_380/Netgear/R8000/
ok this going to be my 1st time trying,
is this correct order?
netgear OFW --> X7.2 --> X7.9
then to change it back to netgear
x7.9 --> merlintoOFW?
yes, that is correct
I can figure out how to flash the initial 7.2 chk file... but after that to update to the 7.9 version, don’t I need a try file? In that link to the files, I only see another chk file for the 7.9 update. Or am I missing something? Thanks again!
I meant trx file, not try... I can’t figure out how to edit my post. Sorry.
Check one of the last posts by himmon on page 1 for the link to the 7.9 version .trx file.
This is translated from the koolshare forum:
[Original / Merlin] brush [koolshare revision firmware]:
Uploading the excessive firmware of the .chk suffix directly under the original factory/Merlin firmware upgrade page is provided below this post;
After restoring the factory settings in the excessive firmware, use the koolshare revision firmware with the .trx suffix.
After waiting for the flashing machine to complete, in the [System Management] - [System Settings] check: Format JFFS partition at next boot (Next boot formatting jffs partition) and Enable JFFS custom scripts and configs (Open jffs custom script), Click Apply on this page to reset the router after successful application.
After the restart is complete, make sure that the router is connected to the network, then enter the software center, first update the software center to the latest version, and then you can install and use the plug-in.
This worked fine for me on both v7.2 and v7.9 only you loose the Adaptive QoS on v7.9 over v7.2 but I have found I can still set device bandwidth limits in the Asus router app
Just setup Merlin and it's awesome. However can someone guide me to setup Aria2 in soft center. Also WPS function is not turning on.
If you want to enable QoS, you will need to go to tools/other setting and enable BWDPI
I’m on Kong’s latest DD-WRT firmware and would like to flash to this one, I’m very new to this and don’t want to brick my router, I already bricked one and had to
another one. Can anybody supply me with the correct order of flashing from Kong to this firmware? I would appreciate it, thanks in advance.
Buy* and also with this firmware is the uploading of .ovpn configuration file available? Like upload the .ovpn file of my con directly to the router?
ok im on netgear offical stock firmware, what do i need to flash first and son on for this firmware?
If you're flashing from a Netgear firmware you have to use the .chk file. If you are on XWRT-Vortex firmware you must use the .trx file.
What pcqd177 is correct.
Howver, it seems that that Koolshare has provided a .chk file for the latest 380.70 firmware so you can just flash that straight from the OFW.
http://firmware.koolshare.cn/Koolshare_Merlin_Legacy_380/Netgear/R8000/X...
R8000_380.70_0-X7.9.chk
how you reinstalled the original firmware?
I have a Netgear R8000.
Last year I flashed to Tomato as the Netgear firmware was pretty poor (Why do they develop excellent hardware and not invest in quality firmware development) , liked it but it was a bt droppy with WIFI and randomly tied utself up in knots.
Changed to dd-wrt recently, that was pretty unstable. Lots of slow downs and droppy WIFI.
So I've gone to merlin-vortex-Koolshare and so far I'm really impressed. Performance is great, Logging is great, My criticisms are very few. The main one being that I cannot get Site Survey to show 5GHZ info. Not important as I have another piece of software to do that.
Feels a bit strange running what is essentially ASUS firmware on Netgear but it's definitely much better than Netgear.
Some screens are partially in chinese, thats not a problem, most is in good English.
New R8000 X7.9.1 - I haven't tested yet so please read forum link below carefully. I am not responsible for support of this firmware or any issues that may arise due to incorrect installation. I only provide the links.
R8000-X7.9.1.chk
R8000-X7.9.1.trx
Support Url -
http://koolshare.cn/thread-139324-1-1.html (View this url in google chrome browser to translate from Chinese to English)
Checksum details for firmware above:
https://firmware.koolshare.cn/Koolshare_Merlin_Legacy_380/Netgear/R8000/...
Firmware Update Log: September 27, 2018 ( X7.9.1 ):
May 08, 2018 ( X7.9 ):
Thanks, i downloaded both of the files, now which one do i upload first? the .chk file then the .trx or how?
Just the .chk file
Anyone know why 7.9.1 is no longer available in the koolshare website?
Uploaded firmware 7.9, to my R8000, but couldnt get ethernet ports to work. I could only interface with the firmware with wifi.
is there a trick to fix this? In the mean time I went back to OFW.
Asus Merlin firmware installed on netgear x6 router, I can't change it to anything else.
Sorry for gravedigging here.
I recently purchased the R800 and am very interested in setting up the Asus Merlin firmware, as I have been having intermittent drops in connection. I read through this thread, but some of the information is a bit confusing. Would anyone be willing to help me out with a quick step by step. I just really don't want to take a chance bricking something i just spent almost $300 on. The simpler the instructions the better. Any help is greatly appreciated.
*R8000
What if I was to flash netgear r8000 directly to 7.9.1 with the chk file from netgear latest version of firmware... would that brick the router? Also I tried flashing it to 7.2 merlin with the chk file and it rejected it saying incompatible. Any ideas?
