When I tried to use the command "arp -i br0 -s 192.168.1.2 AB:CD:EF:12:34:56" to set the ARP entry, it only gave me the list of ARP entry.
IP address HW type Flags HW address Mask Device
192.168.1.131 0x1 0x2 12:34:56:78:07:24 * br0
123.123.213.1 0x1 0x2 12:23:34:55:9c:e1 * brwan
192.168.1.10 0x1 0x2 12:23:34:44:62:ba * br0
192.168.1.107 0x1 0x2 12:23:34:44:00:7d * br0
192.168.1.104 0x1 0x2 12:12:12:ff:f2:c2 * br0
Any idea about how to set the Perm entry to ARP?
ARP entries are not permanent.
If you want to always keep IP connected to MAC, do it through Address Reservation at:
Netgear GUI, Advanced, Setup, LAN Setup
I want to add an APR Entry for Wake on WAN.
It works! Thanks a lot!
Thank you for reporting back!
