FreshTomato-ARM by kille72 for NETGEAR Routers
Have you checked out the latest tomato builds from kille72? This is a fork from the well known Tomato by Shibby, and is available for the following NETGEAR routers:
You can download the builds in the Downloads section, and see the original thread/discussion over on Linksysinfo.org.
https://www.myopenrouter.com/download
Tags:
ithkiam
Thanks for the efforts in
Thanks for the effort in updating FreshTomato. I am thinking to give it a try on my Netgear R8000. But i would like to know how I can roll back from Tomato to stock firmware. I did a bit search, wasn't able to find a stock firmware in .trx format.
ghost779
Hello when you want to go
Hello when you want to go back to stock. First flashing to ddwrt and then you can flash netgear firmware that is what i could find.
