Have DD-WRT v3.0r35030M kongac running on Netgear R7000P. No other firmware installed. Setup Openvpn client per https://www.privateinternetaccess.com/helpdesk/guides/routers/dd-wrt-3/d...
State was "connected" for about 2 minutes, then nothing. Internet works fine, but no matter what I do, the vpn client will not connect at all.
I've checked it multiple times, and reset to default mutilple times and still it doesn't work
I change the port to 1194 and I get a tls error, which make sense.
ifconfig:
br0 Link encap:Ethernet HWaddr 8C:3B:AD:FE:A6:21 inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:159687 errors:0 dropped:1267 overruns:0 frame:0 TX packets:231211 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:25916387 (24.7 MiB) TX bytes:244557936 (233.2 MiB) br0:0 Link encap:Ethernet HWaddr 8C:3B:AD:FE:A6:21 inet addr:169.254.255.1 Bcast:169.254.255.255 Mask:255.255.0.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 eth0 Link encap:Ethernet HWaddr 8C:3B:AD:FE:A6:1F UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:551336 errors:0 dropped:10 overruns:0 frame:0 TX packets:343261 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:422309141 (402.7 MiB) TX bytes:126644866 (120.7 MiB) Interrupt:179 Base address:0x4000 eth1 Link encap:Ethernet HWaddr 8C:3B:AD:FE:A6:21 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:146381 errors:0 dropped:0 overruns:0 frame:119961 TX packets:250284 errors:8 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:17688391 (16.8 MiB) TX bytes:259948356 (247.9 MiB) Interrupt:163 eth2 Link encap:Ethernet HWaddr 8C:3B:AD:FE:A6:22 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:26167 errors:0 dropped:2 overruns:0 frame:0 TX packets:54497 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:2750463 (2.6 MiB) TX bytes:53470978 (50.9 MiB) lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MULTICAST MTU:65536 Metric:1 RX packets:69 errors:0 dropped:0 overruns:0 frame:0 TX packets:69 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1 RX bytes:5426 (5.2 KiB) TX bytes:5426 (5.2 KiB) vlan1 Link encap:Ethernet HWaddr 8C:3B:AD:FE:A6:1F UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:253273 errors:0 dropped:264 overruns:0 frame:0 TX packets:226406 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:170113773 (162.2 MiB) TX bytes:105925968 (101.0 MiB) vlan2 Link encap:Ethernet HWaddr 8C:3B:AD:FE:A6:20 inet addr:72.199.142.123 Bcast:72.199.143.255 Mask:255.255.252.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:297973 errors:0 dropped:3256 overruns:0 frame:0 TX packets:116855 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:240035381 (228.9 MiB) TX bytes:19345854 (18.4 MiB)
route:
Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface default ip xx.xx.xx.xx. 0.0.0.0 UG 0 0 0 vlan2 xx.xx.xx.xx * 255.255.252.0 U 0 0 0 vlan2 127.0.0.0 * 255.0.0.0 U 0 0 0 lo xx.xxx.xx.xx * 255.255.0.0 U 0 0 0 br0 192.168.1.0 * 255.255.255.0 U 0 0 0 br0
ip link show:
nk/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 2: teql0: ,multicast,up,lower_up>mtu 1500 qdisc noop state DOWN qlen 100 link/void 3: eth0: mtu 1500 qdisc fq_codel state UNKNOWN qlen 1000 link/ether 8c:3b:ad:fe:a6:1f brd ff:ff:ff:ff:ff:ff 4: [email protected]: ,multicast,up,lower_up>mtu 1500 qdisc noqueue master br0 state UP qlen 1000 link/ether 8c:3b:ad:fe:a6:1f brd ff:ff:ff:ff:ff:ff 5: [email protected]: ,multicast,up,lower_up>mtu 1500 qdisc noqueue state UP qlen 1000 link/ether 8c:3b:ad:fe:a6:20 brd ff:ff:ff:ff:ff:ff 6: eth1: ,multicast,up,lower_up>mtu 1500 qdisc fq_codel master br0 state UNKNOWN qlen 1000 link/ether 8c:3b:ad:fe:a6:21 brd ff:ff:ff:ff:ff:ff 7: eth2: ,multicast,up,lower_up>mtu 1500 qdisc fq_codel master br0 state UNKNOWN qlen 1000 link/ether 8c:3b:ad:fe:a6:22 brd ff:ff:ff:ff:ff:ff 8: br0: ,multicast,up,lower_up>mtu 1500 qdisc noqueue state UP qlen 1000 link/ether 8c:3b:ad:fe:a6:21 brd ff:ff:ff:ff:ff:ff ,multicast,up,lower_up>
I am on a little bit older version but the only problem I ever had with setting up PIA was the certificate download. When I opened it in notepad to copy it and pasted it in the DD-WRT CA CERT box at bottom it did not paste the whole thing and I couldn't connect. So make sure the entire thing is pasting. I was highlighting and using copy/paste. Once I did it the way they said using control a, control c, and control v it worked fine. Also make sure you pasted the other commands one per line in additional config box(I have one more but don't remember why but it works so I don't change anything, added at bottom):
Everything else I did exactly as listed in the link above(same as your link but yours had a couple ghost characters at the end and went to a dead page for me).
If all else fails this post from PIA forum has a script from a long time member you might want to check out:
https://www.privateinternetaccess.com/forum/discussion/345/setting-up-dd...
Hope this helps, if not let me know I will paste a screenshot of my config but like I said everything else is identical to their support page.
OldSkool
Not sure why my link to PIA support page didn't post but here it is:
