Openvpn Client setting for PIA
3 posts / 0 new
pepbrow
Have DD-WRT v3.0r35030M kongac running on Netgear R7000P. No other firmware installed. Setup Openvpn client per https://www.privateinternetaccess.com/helpdesk/guides/routers/dd-wrt-3/d...
State was "connected" for about 2 minutes, then nothing. Internet works fine, but no matter what I do, the vpn client will not connect at all.
I've checked it multiple times, and reset to default mutilple times and still it doesn't work
I change the port to 1194 and I get a tls error, which make sense.
ifconfig:
br0       Link encap:Ethernet  HWaddr 8C:3B:AD:FE:A6:21
          inet addr:192.168.1.1  Bcast:192.168.1.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:159687 errors:0 dropped:1267 overruns:0 frame:0
          TX packets:231211 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:25916387 (24.7 MiB)  TX bytes:244557936 (233.2 MiB)
br0:0     Link encap:Ethernet  HWaddr 8C:3B:AD:FE:A6:21
          inet addr:169.254.255.1  Bcast:169.254.255.255  Mask:255.255.0.0
eth0      Link encap:Ethernet  HWaddr 8C:3B:AD:FE:A6:1F
          RX packets:551336 errors:0 dropped:10 overruns:0 frame:0
          TX packets:343261 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:422309141 (402.7 MiB)  TX bytes:126644866 (120.7 MiB)
          Interrupt:179 Base address:0x4000
eth1      Link encap:Ethernet  HWaddr 8C:3B:AD:FE:A6:21
          RX packets:146381 errors:0 dropped:0 overruns:0 frame:119961
          TX packets:250284 errors:8 dropped:0 overruns:0 carrier:0
          RX bytes:17688391 (16.8 MiB)  TX bytes:259948356 (247.9 MiB)
          Interrupt:163
eth2      Link encap:Ethernet  HWaddr 8C:3B:AD:FE:A6:22
          RX packets:26167 errors:0 dropped:2 overruns:0 frame:0
          TX packets:54497 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:2750463 (2.6 MiB)  TX bytes:53470978 (50.9 MiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING MULTICAST  MTU:65536  Metric:1
          RX packets:69 errors:0 dropped:0 overruns:0 frame:0
          TX packets:69 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:5426 (5.2 KiB)  TX bytes:5426 (5.2 KiB)
vlan1     Link encap:Ethernet  HWaddr 8C:3B:AD:FE:A6:1F
          RX packets:253273 errors:0 dropped:264 overruns:0 frame:0
          TX packets:226406 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:170113773 (162.2 MiB)  TX bytes:105925968 (101.0 MiB)
vlan2     Link encap:Ethernet  HWaddr 8C:3B:AD:FE:A6:20
          inet addr:72.199.142.123  Bcast:72.199.143.255  Mask:255.255.252.0
          RX packets:297973 errors:0 dropped:3256 overruns:0 frame:0
          TX packets:116855 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:240035381 (228.9 MiB)  TX bytes:19345854 (18.4 MiB)
route:
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
default         ip xx.xx.xx.xx. 0.0.0.0         UG    0      0        0 vlan2
xx.xx.xx.xx     *               255.255.252.0   U     0      0        0 vlan2
127.0.0.0       *               255.0.0.0       U     0      0        0 lo
xx.xxx.xx.xx    *               255.255.0.0     U     0      0        0 br0
192.168.1.0     *               255.255.255.0   U     0      0        0 br0
ip link show:
nk/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: teql0:  mtu 1500 qdisc noop state DOWN qlen 100
    link/void
3: eth0:  mtu 1500 qdisc fq_codel state UNKNOWN qlen 1000
    link/ether 8c:3b:ad:fe:a6:1f brd ff:ff:ff:ff:ff:ff
4: vlan1@eth0:  mtu 1500 qdisc noqueue master br0 state UP qlen 1000
5: vlan2@eth0:  mtu 1500 qdisc noqueue state UP qlen 1000
    link/ether 8c:3b:ad:fe:a6:20 brd ff:ff:ff:ff:ff:ff
6: eth1:  mtu 1500 qdisc fq_codel master br0 state UNKNOWN qlen 1000
    link/ether 8c:3b:ad:fe:a6:21 brd ff:ff:ff:ff:ff:ff
7: eth2:  mtu 1500 qdisc fq_codel master br0 state UNKNOWN qlen 1000
    link/ether 8c:3b:ad:fe:a6:22 brd ff:ff:ff:ff:ff:ff
8: br0:  mtu 1500 qdisc noqueue state UP qlen 1000
    link/ether 8c:3b:ad:fe:a6:21 brd ff:ff:ff:ff:ff:ff,multicast,up,lower_up>,multicast,up,lower_up>,multicast,up,lower_up>,multicast,up,lower_up>,multicast,up,lower_up>,multicast,up,lower_up>,multicast,up,lower_up>
OldSkool1323
I am on a little bit older
I am on a little bit older version but the only problem I ever had with setting up PIA was the certificate download. When I opened it in notepad to copy it and pasted it in the DD-WRT CA CERT box at bottom it did not paste the whole thing and I couldn't connect. So make sure the entire thing is pasting. I was highlighting and using copy/paste. Once I did it the way they said using control a, control c, and control v it worked fine. Also make sure you pasted the other commands one per line in additional config box(I have one more but don't remember why but it works so I don't change anything, added at bottom):
  • persist-key
  • persist-tun
  • tls-client
  • remote-cert-tls server
  • auth-nocache
Everything else I did exactly as listed in the link above(same as your link but yours had a couple ghost characters at the end and went to a dead page for me).
If all else fails this post from PIA forum has a script from a long time member you might want to check out:
https://www.privateinternetaccess.com/forum/discussion/345/setting-up-dd...
Hope this helps, if not let me know I will paste a screenshot of my config but like I said everything else is identical to their support page.
OldSkool
OldSkool1323
Not sure why my link to PIA
Not sure why my link to PIA support page didn't post but here it is:
