Voxel openvpn server custom config
2 posts / 0 new
rupertlp
Hi everyone I am new in voxel, my question is there any detail guide to setup openvpn server with custom config like changing the cipher etc
i can success with custom cert, but I cannot find any info to change the config file .for fine tuning, can anyone help?
Voxel
You have to edit the file
/etc/init.d/openvpn
it generates OpenVPN server configs. You can change this to your own custom settings. Lines in this file such as:
dh $dh
ca $ca
cert $cert
key $key
dev tap0
server-bridge nogw
proto ${proto}4
port $port
keepalive 10 120
verb 3
mute 5
log-append /tmp/openvpn_log
writepid /tmp/openvpnd.pid
status /tmp/openvpnd.status
mtu-disc yes
topology subnet
script-security 2
ncp-ciphers AES-128-GCM:AES-256-GCM:AES-128-CBC:AES-256-CBC
cipher $cipher
auth sha1
tls-server
client-to-client
duplicate-cn
$complz4
$pushlz4
$fastio
client-connect "$push tap"
sndbuf $sndbuf
rcvbuf $rcvbuf
push "sndbuf $sndbuf"
push "rcvbuf $rcvbuf"
