Bricked R7000, COM3 connection giving garbage
6 posts / 0 new
GJSchaller
In the process of updating my R7000, it got bricked.  I went through all the guides, got the TTY cable, opened the router, configured Putty, and booted the router... and this is the output I got in the Putty console:
I verified the Putty settings: 8,1, off - no dice.  I also verified the correct cables were on the correct posts.  Windows 10 had no issue installing the TTY cable, the correct drivers were picked up without a problem.
Any idea how to get past this, or is this one good and truly bricked beyond cybermancy?
GJSchaller
Image of output didn't show
Image of output didn't show up in post, can be seen at: http://www.psi-13.com/pics/TTY-Output.PNG
mrdon213
Check your baud rate, it
Check your baud rate, it should be 115200 .
GJSchaller
Checked that, even tried 9600
Checked that, even tried 9600 as well to be safe.  Same output on both.
pb1983
for Linksys but maybe worth a
GJSchaller
Figured it out.  I had the
Figured it out.  I had the Baud set to 11,520, not 115,200 - once I spotted the comma in another post, I saw my error, and fixed it.
I'm good now, thank you!
