Wan speeds are horrible.. please help
3 posts / 0 new
jkhall
I have just installed DD-WRT kongs on my R9000.   my goal is/was to use openvpn.
before install I was constantly able to acheive 400+Mbps to www.fast.com
After DD-WRT install I am lucky to acheive 96Mbps to www.fast.com without the VPN enabled and with enabled its 30-40Mbps to www.fast.com
when I put another (old router) on the network I am able to acheive the 400+Mbps so I know at the same point in time my ISP service is not the issue.
Has anybody else experienced such a huge drop in wan performance?  I have not done any optomizations other htan change the wifi from 20 to 80MHz.
Please help... :(
jrumj20666
I'm having the same issue but
I'm having the same issue but doesn't look like anyone can assist with this issue.  Did you ever find a solution?
inewton888
Guys, Kong's firmware is old.
Guys, Kong's firmware is old.  You guys need to ugrade with newer firmware from Brainslayer.  Brainslayer continued the work on R9000.  Search on the DD-WRT forums.
