I have just installed DD-WRT kongs on my R9000. my goal is/was to use openvpn.
before install I was constantly able to acheive 400+Mbps to www.fast.com
After DD-WRT install I am lucky to acheive 96Mbps to www.fast.com without the VPN enabled and with enabled its 30-40Mbps to www.fast.com
when I put another (old router) on the network I am able to acheive the 400+Mbps so I know at the same point in time my ISP service is not the issue.
Has anybody else experienced such a huge drop in wan performance? I have not done any optomizations other htan change the wifi from 20 to 80MHz.
Please help... :(
I'm having the same issue but doesn't look like anyone can assist with this issue. Did you ever find a solution?
Guys, Kong's firmware is old. You guys need to ugrade with newer firmware from Brainslayer. Brainslayer continued the work on R9000. Search on the DD-WRT forums.
